Renault megane '05 radio code
Username: Dangerous999
Can someone help me with the code for my original headset
Update list style head unit
Numbers on side of unit
RNRD6950098433
RENRDW240-00
FD01 0519 0098433
8200 483 757
8200483757T K972-security
Can anyone help me, holiday in a few days and I'm driving
Username: Hay88
PortsmouthUk
Post Number: 3458
Dangerous999
code 4176
You must hold at the end to store your code.
IF YOU DONT HAVE A KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AA} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ A] button then rotate the thumb wheel for the correct first digit
Press the [ A] button then rotate the thumb wheel for the correct second digit
Press the [ A] button then rotate the thumb wheel for the correct third digit
Press the [ A] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ A] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
