Adcom GFP 555 II - good preamp?
thasp
So, is it a good preamp? I want to buy it used with a GFA-555. I want it to have a volume knob/dial/switch, and work... no special features.
If not, could you people show me a few cheapie preamps at audiogon.com with two preamp outs(one for amp, one for sub, that I could use simutaneously)? The cheaper the amp and preamp, the more I have for a sub. Age is no matter - as I see it, the older, the cheaper.
Username: Kegger
MICHIGAN
Post Number: 915
well if your looking at 2channel preamps.
i'm not familiar with the adcom but i'm using a
b&k pt3 series II it's fairly inexpensive and for
me works and sounds great.
it has preamp outputs for sub/high/full frequency
3 full sets of preamp outs.
i think i paid $250 for mine.
it also happens to have a remote.
ABC
Yes..its a very good pre amp,had one for 8yrs
also had the 555amp and the 545II hook up to it
I say go for it
Username: Edison
Glendale, CA US
Post Number: 502
Both Adcom and B&K offer good products at good prices.
