Best Sub for $50
Username: Jmmcool
Manistee, MI United States
I'm on a Budget for this. What is the Best 12" woofer for $50 or less. I kno this doesn't leave me much quality, but what are my options.
Username: Rswan
Post Number: 184
for $50 you cant even get a shitty sub, unless its used.
Username: Jmmcool
Post Number: 7
that didn't help
Username: Rswan
Post Number: 185
pyle, dhd, boss, are all cheap subs. its almost not worth paying $50 for them though. save another $100 and you can get a good sub thast will last longer and out perform those cheap ones.
Username: Suicideshifter
Bristolville, Ohio United States
Post Number: 10
check on e-bay, look at this page and this will give you an idea of what you can get.
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
Username: Purplehase_bong
Bc Canada
Post Number: 96
here check this out http://www.cardomain.com/shoplist~b~Boss~t~Subwoofers
Username: Davids2004
Houston, TX USA
Post Number: 292
Kicker comp cvr 10 inch sub should be close on that list. Or xtants lower end sub. Check out www.sounddomain.com and check out the xtant subwoofers or check for them on ebay you can get them for under 50.00 and they are a decent sub.
Houston, TX USA
Post Number: 293
Here you go. All subs are under 50.00 before shipping.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3291&item=5708895584&rd=1 &ssPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39772&item=5708863553&rd= 1
http://www.cardomain.com/item/XTAZ124
http://www.cardomain.com/item/COUBP104
http://www.cardomain.com/item/MTXRT1004
http://www.cardomain.com/item/PIOTSW255C
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39774&item=5708652562&rd= 1
Username: Insearchofbass
Post Number: 7
for 50 bucks and plans for say 300 rms power to an amp id say try a kicker comp 12 in a 3.5 cf sealed box from the curves on box program ive used should hit very well. Me and my cousin did this kicker comp 12 not the vr and i measured him at 126 db with a profile 400 watt amp at less than three quarter gain in about 1.75cf sealed including polly fill but after lookin at kickers site and seeing it can perform in a 3.5 cf sealed box and is intended for an sq use and it greatly increases our best hit frequency im going to get him to put the speaker in this size box sealed and see him hit even more spl and sound better.
thanks,
in search of bass
cost= $76 amp $60 speaker plus the cost to build your own box
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 814
get a cerwin vega HED12 DVC subwoofer
Username: Southernrebel
Louisiana USA
Post Number: 86
kicker Comps or Comp VRs....both are good subs
my first system had a pair of Comp 10's and an IX402 amp...i recommend them for anyone on a budget.
