Radio code
Username: Xazy
SheffieldUk
please can somebody find me the radio code of my Peugeot 206. Car was built in 2000. The serial number CL041010285176 Model PU-2325A. Thank you. Xazy
Username: Hay88
PortsmouthUk
Post Number: 3457
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
