Post all the letters+numbers on any labels,barcodes or stamped in the metal casing including the Serial Number beginning with BP++++++++++++ and the number beginning with 7++++++++++
Hi I recently had the gear box changed for my peogeut 206 (2001) and they disconnected the battery so i now cant listen to my radio without a code, ive got the serial number: CL0410Z0181678 PU - 2325A(B) there were a couple of other numbers on it but i dont know what they are for, hopefully these are the ones needed. please help me many thanks
Posted on Sunday, May 15, 2011 - 05:14 pm: Hi I recently had the gear box changed for my peogeut 206 (2001) and they disconnected the battery so i now cant listen to my radio without a code, ive got the serial number: CL0410Z0181678 PU - 2325A(B) there were a couple of other numbers on it but i dont know what they are for, hopefully these are the ones needed. =================
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
