How many DB's
moses
how many db's would 2 adire shivas in a 1.5 box with a jbl 600.1 powering it?
Username: Jonathan_f
GA USA
Post Number: 721
I'm assuming you mean 1.5 cu ft per sub, and a sealed box. Anyway, they should be in the mid to high 130s, possibly 140s. It also depends on the vehicle.
moses
how many db's would a brahma with a jbl 600.1 reach?
moses
Username: Sploosh56
Post Number: 285
One again depends on the vehicle and the box. If in a ported box it will hit low 140's.
Username: Sploosh56
Post Number: 286
Username: Rlr
Jackson, Ohio
Sorry to be jumping on this post but how many db would my two 15" MA Audio XL hit in a sealed ma box. I have a 95 Dodge Neon.
Username: Rlr
Jackson, Ohio
Post Number: 7
how many db would my two 15" MA Audio XL hit in a sealed ma box with a 300 rms going to them. I have a 95 Dodge Neon 4 DOOR.
GA USA
Post Number: 724
Moses, what size Brahma are you talking about? A Brahma 12 will be in the 140s in a ported box, like Wahl said, while the 15" CAN approach 150 db if the box is right and the vehicle is good for it.
Username: Sploosh56
Post Number: 287
Basically Brahmas are loud as hell and sound good doing it.
