hi could anyone help me with my renualt scenic just brought the car and the radio needs a code the details ive got are model no: 22dc259/62r toq184 rn259f10017093 prod no fdo501210017093 7700434426tq184
Gti_jon code 9851 You must hold at the end to store your code. IF YOU DONT HAVE A KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AA} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ A] button then rotate the thumb wheel for the correct first digit Press the [ A] button then rotate the thumb wheel for the correct second digit Press the [ A] button then rotate the thumb wheel for the correct third digit Press the [ A] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ A] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and HOLD button 6 to store. for 10 seconds
