Trying to power 3 15in l7 dual 4ohm
Username: Urestim
im looking for an amp that will power my 3 15in l7 dual 4ohmi was looking into a 7000watt kole audio or a 6000watt performance teknique any suggestions?
Username: John253a
Post Number: 12
There are some questions you need to answer first,
Are you going to run
sub in series then parrell all 3 to give 2.6ohms
or
parrell then series to give 0.66ohms?
What type of box/size box?(as it determines rms required)
How much do you want to spend?
The specs on the 2011 l7 15 is
Sealed= 1000wrms ea
Ported= 750wrms ea
My self idd run sub in series then parrell at 2.6ohms
Look for an amp that will do 2ohms stable, and produces either 2000wrms @2ohms for ported or 3000wrms@2ohms for sealed
If you get an amp the produces more, then you are more likely to turn it up above what there rated for and blow subs up
