you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Then post the numbers/letters from below the main fat barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
Hi, I need a radio code for my renault laguna (Tunerlist radio, not sure if it is the one that originary came with the car) model no: 22DC279/62Z below the first bar code there are these numbers (NOT SURE IF THEY'RE PART OF THE MODEL NO): T0S018 RN279F10140241 product no: FD0101350140241 security no: 8200002607TS018 ?? no: BG0V0525412231 Will be grateful if i can get help on this!!
