Bloqueo
Username: Niki78
como desbloquear la radio cd 6000 del ford focus c-max
Username: Regrooster
Post Number: 7039
The radio SERIAL NUMBER is required for a code
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display your Serial Number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
It usually begins with M++++++ or V++++++
