Won't the seats move if they are not connected together
Username: Nency
Post Number: 165
The seats weigh about one hundred pounds and will not normally move on carpet. They will, however, move when installed on hardwood or tile floors. If this is a concern, connector plates can be purchased through us for installation on hardwood or carpet, but we recommend a more economical solution of hooking them together with simple straps hidden under the bottom of the chairs.
Need to Register?
Forgot Password?
Enable HTML code in message
