clio 2006 dci
Username: Mariu
Hy there, can anyone tell me my code?
its a radio from a clio 1.5dci from 2006.
model no: 22DC239/62T
RN239F500018030
prod no: FD0505340018030
8200113801TN653
8200 113 801 --c
hope you can help me, i'm loosing my mind.
thanks a lot in advance
Username: Hay88
Post Number: 124
hi Mariu your code is 2332 how to enter text below
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press buttons 6 OR 5 to store. for 10 seconds
Username: Regrooster
Post Number: 3405
Try code 2332
Moderator
Username: Admin
Post Number: 9759
