New member Username: Kev123
Post Number: 1 Registered: May-11
Posted on Hi just bought a clio for my daughter but no radio code. Model no 22dc258/62B prod no FD010141012279. can anyone help please |
Gold Member Username: Regrooster
Post Number: 6941 Registered: Aug-08
Posted on Sorry...this is insufficient information The radio has to be removed from the dashboard Then post the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode |
Post Number: 2 Registered: May-11
Posted on Hi Thanks for info wasn't sure how much info required. Heres the serial no RN258F10122179 and security no TOC263 |
Post Number: 6948 Registered: Aug-08
Posted on try code 1759 |
Post Number: 3 Registered: May-11
Posted on Thanks Reg code worked a treat. Very happy daughter |
