Clarion Autoradio DRB6275R Code
Username: Schagerlhelmut
Please send me the security code from Clarion DRB6275R SNr.CL0262S0002289
Thank You
There is also the number EN60825.1991 on the radio
Username: Regrooster
Post Number: 6930
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
There is alsow a number inside on the chassis : Y5Y2228018
please tell me if this can help us
Thanks
Post Number: 6938
Read the previous answer again.
If there is no C7000000++++ barcode serial number then there is no code that can be calculated for free...Sorry
