Proper code(s) Comcast DVR Remote for ProScan 35160?
Username: Bobmct
Just got my comcast DVR today and had to hook it up with component cables to the TV. The new remote states to use code 0047 for ProScan which allows just a very, very few functions to work. When I try to code-find feature I end up with the same thing.
Had anyone been able to get this type of remote programmed for this or any ProScan model successfully? While I'm mentioning... my ProScan remote doesn't fully work as well. Only the Menu/setup seems to work. Not power or channels.
Suggestions please?
Username: Turtlebug
0030 works
Username: Zingostarr
Wow, 0030 worked for my proscan also, thanks Turtle's Mom!
Need to Register?
Forgot Password?
Enable HTML code in message
