Mid's and Tweeters
Username: Shnosh
I am working on getting my car sounding better. It sounds great but there is one problem. I have a sub box and the amp has a built in crossover but signal going to my other speakers (direct from my deck) is still full range. Is there something that I can put on the speaker wire that will eliminate the lower frequencies? I know that there are crossovers and other components that do it but I am looking for a cheep way out.
Thanks!
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 131
Passive crossovers (goes by many names: filters, bass blockers, chokes) can be purchased for about $15 apiece (Lightning Audio is a decent manufacturer).
Or you can make your own for about $5:
http://www.termpro.com/articles/xover2.html
-Matt
