jbuoygvu Unregistered guest | what kind of vehicle is better for bass, a car or a truck? i know SUVs are the best but whats better out of a car or truck |
Bronze Member Username: Purplehase_bongBc Canada Post Number: 83 Registered: Apr-04 | it depends were u put the subs |
Silver Member Username: RswanPost Number: 161 Registered: Apr-04 | any vehicle that allows you to have an open space that goes directly into the cab i.e. hatchbacks, wagons, suv's, trucks's etc, are good vehicles. better than a vehicle with a sealed trunk. |
Anonymous | YUP swan is right again |
jbdftgfnh Unregistered guest | well i was thinking of getting two 15's and putting them in a 1997 dodge dakota ext cab, how should i face them, im going to make a box for them, im looking for mostly spl so i decided to go with the re x-xx's and a zapco amp, i was thinking of putting them face up or angled up but im not sure any opinios on what i shoud do? im looking for spl but i want it to maintain decent sq since the subs will be right behind me |
Silver Member Username: Davids2004Houston, TX USA Post Number: 239 Registered: Jun-04 | Most people who put them in extended cabs face them down which will give you a little better bass since it will be bouncing off the floor or face them upwards. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3797 Registered: Dec-03 | hatchbacks tend to have the best results.. things like firebirds, civic hatchbacks, CRXs, etc. |
Bronze Member Username: CbigchrisbPost Number: 16 Registered: Jun-04 | nice choice man. you will get more than decent sq |
jbfgvhj Unregistered guest | do u think i should seal the box or port it? and im probably going to face it angled upwards kind of toward the windshield, because making a box and putting them face down is too hard for me, but im still opened for suggestions on how to do this. and will this wireing kit be enough for my amp and subwoofers http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogn o=TSX4404. thank u |
jbfgvhj Unregistered guest | ????????? |
Silver Member Username: RswanPost Number: 173 Registered: Apr-04 | my friend had built a custom box in his chevy S10. he took out the fold down seats in the back and built his box to fit inside the space. he was running two rockford subs ( one in each spot where the seats used to be) and it was loud as hell. so if you could do that then i would try it. either way make your box sealed. if you build a ported box it wont sound that good in an open cab. but thats just my opinion. if you can build the box like my friend did i would go for it you will definitely be hittin some hard a$$ db's |
jbfgvhj Unregistered guest | Do u think that will be enough for my wiring though? and how many db's do u think i could hit if im putting them in a sealed enclosure right behind my seat? |
Silver Member Username: Jonathan_fGA USA Post Number: 706 Registered: May-04 | You said you're going for mostly SPL, so I'd do a ported box. If you tune the box low (around 28 hz), you'll get great SQ and a LOT of SPL, for even more SPL tune the box around 35 hz. Two X.X.X. 15s in a ported box in a truck with the right power should hit in the neighborhood of 150 db. Depends on the truck though, can't tell you exact numbers as I haven't done many Dakotas. |
