AHHH! What kit!? Quick!
Username: Jonez788
Post Number: 35
I need a 4 gauge kit that can handle 800 watts RMS. WHAT ONE should I get?
Username: Rswan
Post Number: 162
you have to get a bigger gauge wire. you can try it but i wouldnt reccomend running that much watts on a 4 gauge amp kit, unless it specifically says it can handle 800watts of constant power
Username: Jonez788
Post Number: 36
well, im not running it to the trunk, so it won't be as far. Can anybody reccomend me a kit then?
Username: Grmncrsnbr
VA
Post Number: 133
swan why is it then that most kits for a 1000W amp come with 4g wire? you should be fine with 4g check out http://knukonceptz.com/
Username: Rswan
Post Number: 168
the bigger the cable the more power can pass through. you need bigger gauge wire than a 4 gauge for a 1000 watt amp, or its a complete waste of wattage.
