Code For old Tape BMW deck
Username: Rounderace85
I saw an old post April 09 that you helped get a code for a radio... Im rebuilding a 1985 BMW 318i and I recently purchased a BMW radio at a Junk yard the number stamped on it is F70922964A.. any Idea how i might go about getting the code for It.... not sure if the car it came from was a 1985 but it was a E30 (model)
Thanks in advance for your consideration.....
Username: Regrooster
Post Number: 6778
post the radio make and model and any more details on the radio label or case
Some of the other numbers besides the one on he back are... inside and are...
SANKYO BFE2L03.70805-B
GZ75E82B
GZ75E61A
8737-2LC
TR1AP620 8736-5NC
??9.17
I think It may be a ALPINE back in 2008 you solved two codes for two brothers that had the serial no. beggining in F #########A and ending in A not sure ..l.a lable fell off at the junyard .. you can still see where it was attached...
Post Number: 6797
This is not an Alpine.
If this is a SANYO then I don`t think you are going to get this from anywhere on the Internet.
It will had to be taken into a Radio Decoding Service so that they can open it up and read the code inside the memory chip.
You could try emailing
restoredclassic@aol.com
to see if they can help as they have provided codes for old BMW radios in the past
Mention this forum
However it might just be cheaper to buy another radio
Thank You any way for taking the time to try and help I apreciate this enormously.....
Manny
