RENAULT KANGOO CODE??
Username: Alscho
HI,
JUST BOUGHT A RENAULT KANGOO AND THE GUY TOLD ME I NEEDED TO RUN THE RADIO FOR A HALF HOUR AND THEN ENTER THE 4 DIGIT CODE WRITTEN ON THE USER MANUAL. I WAS ABLE TO ENTER THE CODE BUT THE RADIO CONTINUED TO DISPLAY "ERROR". I'M WONDERING IF THE RADIO HAS BEEN CHANGED AND THE CODE IS FOR THE OLD RADIO.
THE SERIAL NUMBER IS: RN279F50454269
THE BARCODE IS: 7700433948TT140
THE CODE I WAS GIVEN WAS 2879...
IF THIS IS CORRECT COULD ANYONE SUGGEST WHAT ELSE I COULD BE DOING WRONG...?
THANKS
Username: Regrooster
Post Number: 7127
the correct code is 6871
Username: Alscho
WORKS GREAT. THANKS REG! YOU JUST SAVED ME A COUPLE OF POUNDS!
