A lot of contagious files - how do i remove them
Username: Shane1234567
hiya all
i just had a computer of my parents for free to put in my new home for some internet use fo rmy self, very thoughtful off them
but i took all the pics, music etc etc of it as i didnt want there stuff on here
well chatting to a mate and he said do a dick defragment on the comp to make it faster, well i done that
i did notice a load off contagious files when i did it, it was about 70% off the screen full of them..
any idea how i remove them,
my mate said to remove windows and re install windows XP and turn it back to factory setting and then start adding my own stuff back on
any ideas and help will be great
Username: Ieee488
Post Number: 383
contagious files?
never heard of them
Username: 420pimp2
Baltimore Atlantic Ci..., MD, NJ
Post Number: 993
contiguous files! (well chatting to a mate and he said do a dick defragment ) ? wow
Username: Doreenakadj
Post Number: 4565
sounds like you have spyware
try this to remove it all
http://dl.phazeddl.com/2733227/PC_Tools_Spyware_Doctor_8.0.0.602/if this file doesn't work please let me know and I will find one that does
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 16000
x2
Username: Blakktalon
Post Number: 50
malwarebytes works well. the free version should update and remove all of the spyware thats on your pc.
Post Number: 16834
thats another option
Username: Pkenny01
Contiginous means that the files are in the right order with the different parts of the file next to each other. (This is what a disk defragmentation does - I liken it to putting all the things needed for baking a cake in the same kitchen cupboard, this would be faster than if they are spread out over the different cupboards).
Contagious means could be virus ridden. I'd try either search and destroy spybot or lavasoft adaware (both free and good)
Need to Register?
Forgot Password?
Enable HTML code in message
