Renault radio 22dc229/62
Username: Freud34
Hi,
I've just replaced the battery on my Kangoo and I need help about radio code, the guy who sold the car to me didn't give me the code Can someone help me?
Here's the info written on radio:
Model number: 22DC278/62
T0T505
RN229F30169201
Product number FD0503380169201
Regards,
Fred
Username: Hay88
PortsmouthUk
Post Number: 3406
fred
code 6400
You must hold at the end to store your code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Freud34
Hi hay88
Big big thanks, your are a chief !!
I could listen again my favorite songs,
Have a nice day
