Kicker 15L72
BOOM BOOM
i have a kicker kx1200.1 which is 1200x1 ohm...
if i get S15L7 DVC 2ohms, would i get the matching right? if i wire them parallel to get the 1 ohm, would it be perfect for my amp? help...
Hydro
Yea If u wire that sub in parallel it will be 1 ohm just make sure your using a small gauge for ur power and ground wires I would go with at least 2 gauge.
rosebudd
boom boom,
if your woofer is a dual 2 ohm woofer wired in parallel your amp will see 1 ohm. like hydro says 2 gauge wire is best due to the high current nature of that amp. L8r
