New member Username: Altin74
Post Number: 1 Registered: Mar-11
Posted on hi i have lost the code for my radio numbers on side are mod nr 22DC279/62z prod nr : FDO202120251557 |
Gold Member Username: Regrooster
Post Number: 6513 Registered: Aug-08
Posted on Sorry...this is insufficient information The radio has to be removed from the dashboard Then post the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode |
Post Number: 4 Registered: Mar-11
Posted on MODEL NO : 22DC279/62Z T0K775 RN279F20251557 PROD NO : FD0202120251557 |
Post Number: 6518 Registered: Aug-08
Posted on try code 4547 |
