Bmw code
Username: Decode
POLAND
Post Number: 630
please help code PH7850V1285713 or PH7850S1093926
thanks
Username: Mikeb318i
Hello. It looks like I'm not the only one. Could I please have the code for mine, too. I replaced my battery and . . . .
BMW Business CD
BP027319910462
7640273342/40/44
Thank you!
Username: Hay88
PortsmouthUk
Post Number: 3398
Mikeb318i
code 1667
Username: Mikeb318i
Thank you hay88. That was a very quick response. It didn't work for me. I can't get it to make a 7. Does it make a difference that I'm in the USA?
Username: Mikeb318i
Didn't work. I can't make a 7. Is there a different code for the USA?
Username: Regrooster
Post Number: 6455
Yes..I think you will require a 5 digit code
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Post Number: 6456
Michael
Username: Decode
POLAND
Post Number: 630
Posted on Wednesday, March 23, 2011 - 06:31 am:
thanks
Sorry...no traders or dealers
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Username: Decode
POLAND
Post Number: 632
hello this is my first code why you call me dealer
you only need say sorry we can't help best regards
Post Number: 6459
You are asking for 2 codes in one request
Username: Decode
POLAND
Post Number: 634
yes i have 2 radios i buy on ebay and i repair it to my e36 BMW i don't know which one is ok ,because selers say one of them for spares or repair so if this trouble give code for one of them
Post Number: 6465
PH7850V1285713. = 7627
PH7850S1093926 = 5295
Username: Caytepelim52
hilfe bitte
ich habe code vergesen
philips
PH7850X1427442
Post Number: 6514
caytepelim
Posted on Sunday, March 27, 2011 - 07:28 pm:
hilfe bitte
philips
PH7850X1427442
try code 9508
vielen dank alles ok
bitte noch hilfe
ich habe noch eine kenwood autoradio
KE0436K0301855
Post Number: 6527
Sorry....Main Dealer or Radio Decode Service only for this code ( and all KENWOOD codes )
It will not be available for free from anywhere on the Internet
Username: Domeno5
Hello.
Please give the code for the unit, BMW Bavaria C Professional RDS.
SN: BE 1801 R 7762972
Post Number: 6534
Re: Domeno
BMW
try code 4807
Username: Domeno5
Reg Rooster, Thank you.
But unfortunately the code does not work
Post Number: 6550
4807 is the correct code for the numbers given
Try emailing
Mention this forum
Username: Mikeb318i
Hello,
The number stamped in the metal case of my radio is BP027319910462 (I was told it was too many numbers), so I think the actual number is 19910462, which I found on another sticker. Could someone please try to get the code for 19910462?
Thank you!
Mike
Post Number: 6576
MikeB
Username: Mikeb318i
Posted on Friday, April 01, 2011 - 05:56 pm:
Hello,
Thank you!
The 4 digit code is still 1667
However your previous post said that you were in the USA and require a 5 digit code. ( no digit higher than 6 ) This requires a US calculator which is not readily available.
Try emailing
Mention this forum
Username: Mikeb318i
I made it work! If other USA 5 digit codes are required, have them turn the key to accessories (don't start the car) and turn on the radio. Hold the 'M' button for about 10 seconds. Push the '1' button to scroll to 'Europe' and then turn off the key. Turn the key back on (don't start the car) and enter the 4 digit code. It works! I'm actually getting more stations than before. Strange. The BMW dealer told me he couldn't get the code with my serial number and I should replace it with an after market. Thanks for the 4 digit code!
Post Number: 6577
This radio is a hybrid. Using the 4 digit code will tune it to the UK and European range of frequencies.
Username: Jp86
Thanks for this informations.
