Megane 2005 Radio code
Username: Borhan_nasr
Hi, I lost my renault megane radio code
Model No: 22DC257 / 62
RN257F40093176
PROD No : FD0404150093176
Can anyone help me ?
Username: Hay88
PortsmouthUk
Post Number: 3374
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Need to Register?
Forgot Password?
Enable HTML code in message
