I need radio code for Honda Odyssey 2000.
Username: Orios51
Hi my friends, excuse me, I recently bought an used Honda Oyssey 2000 and you know the deal...no code in owners manual or sticker anywhere on the car. Please help!
VIN: 2HKRL1863YH586351
Serial # M99A250525... Thanks in advance!
Username: Regrooster
Post Number: 6322
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PANASONIC
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with
7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If you can supply all the correct details, then they will be able to supply your code for free.
Otherwise you will have to try your HONDA Main Dealer or a Radio Decoding Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Bnicol
Hi, I bought a Smart Passion cabriolet & the seller re-installed the original Smart Grundig Radio Cassette which is now in "safe" locked out mode. The serial number is MC761021092150. Thanks in advance of any help with the unlock code.
Username: Orios51
Unfortunately, i'm not the original owner, that's why i don't have data as email, phone number, etc, that matches with VIN and serial # of radio. So, i better, will put another cd player with mp3 or dvd.
Thanks, any way.
Post Number: 6327
maxsmart
Username: Bnicol
Posted on Sunday, March 13, 2011 - 05:15 pm:
Sorry....Main Dealer or Radio Decode Service only for this code
