I just brought 2 kicker CVR10 10" subz. They are 300 watts RMS and 600 watts max each. I need to buy a amp for them. I need to know whats the best amount of watts the amp should be. Should I get an amp that gives out 300 watts to each sub to match the RMS of the subz? or should i find an amp that gives out watts thats in between the rms and max of the subz? someone please help
John A
you should run the rms amt of wattage to the subs. any amp that would push 300 wattsx2 would suffice. if you run more power than the rms, the chance of blowing the subs is much higher.
