Posted on Saturday, August 21, 2010 - 04:13 am: Hello, could you give me radio code for my SCENIC I (2000) MODEL NO: 22DC259/62P RN259FY0083872 PROD NO: FD0200130083872 Thanks!! ====================================== Sorry ...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Reminder: No mutiple code requests on this forum
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Posted on Saturday, August 21, 2010 - 03:45 am: Hi,
I also am looking for a radio code for my Laguna II 2003 Model no : renrdw100-10 T0T337 RNRD0130073184 Product no : FD0003240073184 8200247962TT337 8200 247 962 ===========================
Posted on Sunday, August 22, 2010 - 05:19 am: Hello,could you give the code for my Laguna 2002 please? 8200002607TB374 MODEL NO 22DC279-62Z TOB374 RN279F20208066 PROD NO FD0202030208066 =======================================
Posted on Friday, August 27, 2010 - 02:08 pm: Hi i need the code asswell. Can anyone help me?. Model No: 22DC279 / 62E TOU 545 RN279FY0002300 Prod No: FD0100470002300
Milutn you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
managed to find my code on top of the radio (Laguna) took three tries -ERROR code flashing and beeping- and during the third; I was pressing lots of buttons, switching it on and off, then it started working.............! BUT, now it beeps every two seconds when the radio/CD is on.
Striver your code 4523 you must hold at end to store code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
if it's a renault you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Hi Adyg1979 post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
Garmenia your code 4299 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Hi, can you help? I need a code for my Laguna Radio/CD I can't see any serial numbers but It has the steering controls so must be original, right? The Vin Number is VF1KG0G0626072642. If you need any further specs please advise where I can locate them. Thanks
Grahame_r you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Please I need the radio code for my Laguna II. I don't know wich of the codes in the labels is the security code, so I post the pictures of the labels.
Silvagno 8 200 089 153 T F172 = 0416 You must hold at end to store code. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Leocadio I105 = 1620 Try emailing restoredclassic@aol.com to see if they can help Mention this forum Silvagno above is having the same it's confused me. if you have any joy please let me know.
HI there new to all of this so I took the battory off my 2003 Renault laguna and now need the radio code i took all the numbers off of the radio, 8200002607TX924 Modle number; 22DC279/622 Product; FD0202340345049
hello can anyone help me with my laguna 2 radio code? I've changed my battery and now I have to enter that code wich I don't have because I bought my renault from other person and he didn't give me any manuals 8200002606TW185. MODEL: 22DC259/62Z PROD NO: FD0201370031067
Jim_jupiter your code 3824 you must hold at end to store code. Code Entry as Follows:
thanks. now I have other problem. I've tried before for a few times to enter a code and now I can't enter the one provided by you because the display only shows CODE and when I press that button it gives me a beep do you know what should I do? it could be broken or blocked?
Please note that code entry is only possible when a number is flashing in the seperate display. If the display continually shows "CODE" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible. so leave turned on untouched until it resets itself. don't touch any button cause if you do the wait time starts from the begining.
that means that I'll have to drive or at least keep the engine running for two hours, otherwise the radio stops itself after a few minutes. I'm thinking, if I totally disconnect the radio from the car, could this reset the radio? thanks again for your help
disconnecting will not help you. you don't have to have the engine running. leave the key in the ignition, turned to position one, and the stereo switched on as well) should only be about 32mins
Hello I have a renault laguna 2004 2.2 dci, i have error on my radio screen, when code entry appears i have tried various different codes ( all the visable ones I can see) but nothing works.. got a 200 mile trip today so am in desperate need of radio. please can someone help Many thanks
Fozmondo your code 9928 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Press " " On The Stalk Control To Enter " 0000 " Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Mackem U223 = code 5757 you must hold at end to store code. if V223 code 4754 Code Entry as Follows:
Hi! I forgot the light switch one day and an hour later the battery had run out, causing a lot of "Dooh!" I have a Laguna II (2002) and would like some help with the radio code.
model no: 22DC279/62z prod no: FD0202150263187 TOU523 RN279F20263187 8200002607TU523
asd your code 1425 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter
Hi Uk9 your code 0514 you Must hold at end to store code. Code Entry as Follows:
Tomcatshs your code 6132 your must hold at end to store code. Code Entry as Follows:
needing a radio code for an 03plate renault Laguna had battery out for ten mins and now radio needs recoded the details on radio are below MODEL N0:RENRDW100-10 T0i837 RNRD0130083453 PROD N0: FD0003270083453 I Think the serial no is 8200247962Ti837 or 8200247962- - - see that you have always managed to help other lost souls would be very helpful if you can see your way to helping this one Many thanks Andy
Needing a radio code for my Renault Laguna (2001). Garage disconnected the battery and I don't have the radio code - Would be very grateful if you are able to help? Model No: 22DC279/62E TOF337 RN279F10005977 Prod No: FD0101080005977 Hoping you can help, Debbie
