Peugeot radio code
Username: Madgeh
Hi,can anyone help me with a code for my Peugeot cd/radio.Mine packed up and a friend gave me one he had taken out of his car,but can't remember the code.It 's a PU2294A,ser no. CL0401X0003717.
thanks Madge
Username: Regrooster
Post Number: 6210
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Username: Madgeh
Well it was worth a try, can't find any c7000000++++ numbers anywhere.What about a Blaupunkt that came out of our old BMW, forgot it was in the shed.It's a Blaupunkt Car 300, NCW (?)90 532 620.Some of the label is missing ,It has Type C ? 300 (D) .
Maybe I can get this one working without having to fork out some money.
Thanks Madge
Post Number: 6212
try emailing
restoredclassic@aol.com
to sort the Blaupunkt out
Mention this forum
Username: Madgeh
Thanks ,I will send them an email.
