Silver Member Username: SatopiaPost Number: 513 Registered: Feb-08 | if your on nfps change to this info shutting down fenfu server as of today Server: wuopoua.dynsite.net Port: 20010 and 20110 Deskey: same as before Donation number: same as before |
Bronze Member Username: Nj2005Post Number: 14 Registered: Jul-06 | right on! |
Bronze Member Username: NrizviLivermore, Ca Usa Post Number: 82 Registered: Dec-07 | Why I have to change?? |
Gold Member Username: Saqeeb9000Post Number: 7611 Registered: Oct-07 | fenfui.dynsite.net = fenfu.dynsite.net is down for maintenance. THERE WILL BE UPS AND DOWNS TODAY. If you are down today on that server please WAIT IT OUT. DO NOT shift to the new server as that is ONLY and ONLY for those BLOCKED by ISP. If anyone tells you otherwise THEY ARE WRONG and I DON'T CARE WHO. Again, DO NOT change servers UNLESS you are blocked by the ISP. I hope that makes it clear to all. |
Silver Member Username: SatopiaPost Number: 514 Registered: Feb-08 | yup they finally posted it the way it should have been posted ,yesterday they had old post looking as if they where shutting old fenfu down 4 good |
Bronze Member Username: Nj2005Post Number: 15 Registered: Jul-06 | sada bhai, I changed to wuopoua last nite and working fine, how this will affect my lil nano in future? |
Bronze Member Username: Maharaja6000CanadaCanada Post Number: 81 Registered: Nov-06 | dear sada,i want to join private iks server .i have i link 8000 pl advice thanks |
Gold Member Username: Saqeeb9000Post Number: 7612 Registered: Oct-07 | harchi check ur pm |
Bronze Member Username: Khopadi1Post Number: 25 Registered: Mar-05 | Hi, SADA can you tell me if 61.5 is working with hindi channels on iksprivateserver/Nfps. Please reply ASAP. Thanks |
Gold Member Username: Saqeeb9000Post Number: 7614 Registered: Oct-07 | j look here no u need 118.8 https://spreadsheets.google.com/ccc?key=t65mKbOD5q_7ZE1sJlbbpxQ&hl=en#gid=2 |
Silver Member Username: Tasmanian_satellitePost Number: 164 Registered: Jun-07 | How do I know if i am blocked by ISP. thanks |
Gold Member Username: Saqeeb9000Post Number: 7615 Registered: Oct-07 | NFPS is doing maintenance work in the network, be patient please. For those who think their donations have stopped working please go to your PC and perform the following test first: 1. Go to Start - Run 2. Type in cmd and press ENTER 3. In the balck screen type in ping fenfui.dynsite.net and press ENTER 4. If you get 4 lines of REPLY, then you MAY NOT be blocked by your ISP, and it is some other problem. If you get REQUEST TIMED OUT, then you ARE being blocked by your ISP and please follow the link above. ISP is blocking mac IDs. They can block the access to the server for the modem (rare occasions), router (most occasions) or the receiver's (rare occasions) mac ID. |
New member Username: AboboPost Number: 1 Registered: Mar-11 | how can I join private server |
Silver Member Username: MrgregPost Number: 661 Registered: Dec-07 | Ask the cricket man. |
New member Username: AboboPost Number: 2 Registered: Mar-11 | how can I reach him |
Silver Member Username: ChaffPost Number: 596 Registered: Jan-10 | https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1940373#POST1940373 monetary risk - iks - $35 Settlement demand letter from dish - $3500 civil suit - $10,000+ |
