Bronze Member Username: SchiftyPost Number: 67 Registered: Oct-05 | my viewsat ultra with weather forcaster wont do anything it just has 9999 on the front,how can I fix it |
Diamond Member Username: NydasPost Number: 20638 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/673793.html |
Platinum Member Username: PlymouthCanada Post Number: 16026 Registered: Jan-08 | Bernie You must put the factory bin! Try this bin: |
Bronze Member Username: SchiftyPost Number: 69 Registered: Oct-05 | where do I get loader 2 it wont work with usb |
Platinum Member Username: PlymouthCanada Post Number: 16031 Registered: Jan-08 | bernie I switched my PC for a new and copied my files but the loader was in the program file, the old Hard disk is formated now! After 2 hour to search for the loader I can't found it! Sorry! If someone can post a link, it will be great! |
New member Username: CoolestaniPost Number: 1 Registered: Mar-11 | hi,i am new in here.i have problem with my satzen z300 it was down for four days.I see many webs about it.. but i didn't find out problem does any one any body help me plz plz plz thanks |
Diamond Member Username: NydasPost Number: 20642 Registered: Jun-06 | Default Viewsat Ultra WF FTA Fix March.03.2011 PLEASE take NOTE the file dated 110303 is the BIN file for the receiver 110302 is for the WF Release notes are INCLUDED. Attached Files * File Type: zip PFTAUSW-110302U.zip‎ (1.11 MB, N/A views) * File Type: zip PFTAUSW-110303U.zip‎ (1.11 MB, N/A views) |
Diamond Member Username: NydasPost Number: 20643 Registered: Jun-06 | I do not know if this is the loader you are looking for or whether it will work for you. |
