Bronze Member Username: ShopvacPost Number: 66 Registered: Jun-10 | Which would you prefer based on overall performance, sundown sax 100.4D or JL Audio XD400/4 ? neglect price. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1949 Registered: Sep-09 | sundown sax 100.4D |
Silver Member Username: MakinblakMonroe/Monticello, La/Ar Post Number: 420 Registered: Oct-10 | x2 but cant go wrong either way |
Platinum Member Username: InsearchofbassPost Number: 16612 Registered: Jun-04 | x3 |
Bronze Member Username: ShopvacPost Number: 68 Registered: Jun-10 | thanks guys |
Gold Member Username: DelsolePost Number: 1816 Registered: Feb-05 | I actually heard one of those small jl amps a while ago and i was very impressed. However I think a more comparable amp would be a jl slash series. From my personal experiences i would use a jl slash series amp all day long over a sundown. Unless space is an issue which i will assume its not since the sundown is a candidate. I have no complaints with sundown, I actually think there great amps that make great power but for this size of amp i will put my money on jl audio. A lot of people think way to highly of sundown and there are obviously a ton of people that wont give jl the time of day because they say you can get more for less. |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16912 Registered: Jul-05 | 25wrms more on the SD though - dunno if that means much to u .... |
Platinum Member Username: InsearchofbassPost Number: 16654 Registered: Jun-04 | it means more headroom so it may |
Gold Member Username: DelsolePost Number: 1817 Registered: Feb-05 | What seems to be more on spec sheets may not be when the meters are taken out. Lets not forget about sundowns 14.4 volt ratings. Although jl rates the xd at 14.4 they also show a rating at 12.5 volts which shows it loosing a small margin of power. Also if you were to look at the slash series its pure power down to 11 volts. Just throwing it out there i believe jl has some closeout prices on there site on the slash series amps that might be worth a look at. |
Bronze Member Username: ShopvacPost Number: 69 Registered: Jun-10 | Appreciate all the responces, Thanks guys. |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16915 Registered: Jul-05 | why only these 2 choices & which did u end up going with ? ... |
Bronze Member Username: ShopvacPost Number: 70 Registered: Jun-10 | leaning towards the sundown, any other suggestion welcome, budget around $400 |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1952 Registered: Sep-09 | http://www.db-r.com/sell/store2/index.php?main_page=product_info&cPath=65_67_69_ 76&products_id=206 http://www.db-r.com/sell/store2/index.php?main_page=product_info&cPath=65_67_69_ 76&products_id=206 |
Gold Member Username: DelsolePost Number: 1818 Registered: Feb-05 | http://cgi.ebay.com/OLD-SCHOOL-PRECISION-POWER-PPI-A404-BLACK-PLUGS-/190497596319?pt=Car_Amplifiers&hash=item2c5a8aa39f Very nice price to.. These are what i will be using for my active 4 way this year. |
