Silver Member Username: Stubbs563Cedar Rapids, Iowa Post Number: 240 Registered: Feb-10 | I got two bottles of of this autoarmor sound sheild from work today and I was wondering if anyone has heard of it. Also if its sound deadner or what it is. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 24429 Registered: Jun-06 | If you got it from work, don't YOU know what it is? Lol. |
Silver Member Username: Stubbs563Cedar Rapids, Iowa Post Number: 241 Registered: Feb-10 | I've never worked with it. The rustproofers use it, or well apparentl never used it. To clarify my obtainig it; I detail at a for dealership and We are doing a rennovation of the shop in our detail shop anmy boss said toss the two containers we had of it. I figured it may be somethog like some deadner sluge or somethin so I took them home with me. I figured maybe that's what it is and I could.get some deadner for the frees. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 24430 Registered: Jun-06 | Canaan. He is install God. We wait his response. |
Silver Member Username: MmaudioconceptsKY USA Post Number: 752 Registered: Jan-07 | its used to keep road noise out of the car. its usually sprayed on the floor panels or under the car. |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 691 Registered: Sep-05 | This might help. http://www.ecpinc.net/products/sound.aspx |
Silver Member Username: Stubbs563Cedar Rapids, Iowa Post Number: 242 Registered: Feb-10 | Thanks for the help everyone. |
