300 MHz MIPS Processor - Linux OS Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1; Fully compliant MPEG-2 MP@HL & MP@ML; Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3) SCPC & MCPC receivable from C/Ku band satellites Multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable) Motor Support: DiSEqC 1.2/1.3 (USALS - GoTo X) MHEG-5 HDMI 1.3 output (HDMI cable not included) PVR (store on USB external disk) Multimedia files playback (by USB); 7 Days Electronic Program Guide (EPG) Teletext and subtitle out through OSD Multi-lingual DVB subtitle and teletext Automatic and Manual Channel Scan Automatic Service Scan NIT search Hardware BLIND SEARCH Fast channel switching < 1 second OSD in many languages and skin-support Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable; LED Display Multiple display mode: 1080i/720p/570p/576i/480p; MPEG-2 / H.264 hardware decoding Videotext Decoder Analog RCA audio output: stereo (L+R); Digital audio output: S/PDIF by coaxial S/PDIF Interface for digital bit stream out (AC-3) YCbCr Component Video Output 2 x Scart (RGB, FBAS or S-Video) Screen format: Auto, 4:3, and 16:9; Upgrade software through USB2.0 port Powerful user interface program management function, parent lock 1x CI built-in 1x CA (smartcard reader) built-in 10/100Mbit Ethernet Interface
Notes:
No 4:2:2 out of the box (not supported) No internal hard-drive included with receiver. You can connect an optional external HD or Flash Memory through USB. HDMI cable is sold seperately
Receiver Specifications
DVB-S2 Input Frequency:950~2150MHz Loop Out Frequency:950~2150MHz Input Level:-65~-25dBm Input Impedance:75 LNB Power: Auto/14v/18v/OFF, Imax = 500mA Video decoder Video Compression MPEG-2 and MPEG-1 compatible, H.246 Video Formats 4:3 / 16:9 Letterbox for 4:3 TV-Device Audio decoder Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3 Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz Output digital Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output Video parameter Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard TV-Scart Output: FBAS, RGB, S-Video Serial Interface RS 232 RS232 bidirectional Bit rate 115,2 kBit/s max. Plug Connector SUB-D-9 Function: Update of Firmware Ethernet 10/100 MBit compatible interface Function: Update of Firmware USB
1 x USB 2.0 Host, PVR
LNB power and polarization per tuner
LNB Current 500mA max. short-circuit-protected LNB Voltage vertical <14v> 11,5V at 400mA LNB Voltage horizontal <20v> 17,3V at 400mA
Physical specification
Ambient Temperature +15 °C...+35 °C Humidity < 80% Size (W x D x H): 300 mm x 220 mm x 56 mm (12in x 8.7in x 2in) Weight: 1,8 kg (4 lbs) without HDD
Power
AC auto input range:100-240VAC 50/60Hz Consumption (Standby): Max. 10W (<1 W)
What is included in the box:
SatHawk PVR800 Receiver IR Remote Control RCA Composite Audio Video cable CD (owners manual)
Not a spam. Good information on a new Receiver brought by Plymouth, a reliable source of information. Chaff has sworn enmity to Plymouth from day 1 of Chaff's registration 14 months ago, and is known disruptor of this forum.
Chaff: Are you saying that sadoun.com refused to advertise at your little visited site and gave the promotion contract of a new receiver to Plymouth? Wow! Plymouth HAS taken away a lot of business from you! A can now understand (though not condone) why you are always after Plymouth.
If you are too stupid to see a very good reseller with the most reputation in the world of satellite with the best support of all, this is a pure FTA receiver like your Pansat but much better which will no be harmed by Dn!
Poeples using a site to promote their site, usualy in their first post!
What about your friend Zulu and his site spaming?
Forum Rules:
Rules and "Netiquette"
When writing your messages, please use the same courtesy that you would show when speaking face-to-face with someone. Flames, insults, and personal attacks will not be tolerated. It's fine to disagree strongly with opinions, ideas, and facts, but always with respect for the other person. Great minds do not always think alike, and that's where the fun is! Also, note that messages express the thoughts of the writers, not the board or its moderators. Note that you are in my target now!
