Code for a renault scenic
Username: Bleg
Bought an 07 scenic grand - the battery went- so, fitted new battery but now the radio wont work. Contacted the garage where i bought the car and they said the code was in the pack supplied.
the radio is RNRDAG70012567
8200562686T
any ideas??
Username: Bleg
is there no one who can help- any ideas of where i could go to get this solved??
Perhaps somewhere local? (i live in Hull, yorkshire for my sins)
Username: Hay88
PortsmouthUk
Post Number: 3265
hi post the numbers/letters from below the main FAT barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Bleg
U543
8200 562 686T
RNRDAG70012567
RENRDW34619
BS0207080012567
These are all the numbers on the radio
Thanks in advance
Username: Hay88
PortsmouthUk
Post Number: 3267
Bleg
u543 = code 5463
You must hold at the end to store your code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
