Radio Code Peugeot - Help Please
Username: Smartie
My daughters radio is asking for a code after the nice RAC man dissconected the battery
Radio Model PU-2294A
Serial number CL040120797315
Can you help me with the code?
Ta
Martin
Username: Regrooster
Post Number: 6001
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
