Archive through May 12, 2010
Username: Charlesana
Hi,
Can you help?
Mine's...
GM 1300V6429438
7645852320
90 532 620
Thanks!!
Username: Aitchgb1
LondonUK
I have tried the code which I used before to unlock my Blaupunkt Car 0300 but it is not working could someone please check my code.
GM0300W6724361
Apologies -
7 648 852 320 CAR 300 (E)
90 533 422
Thanks
Username: Regrooster
Post Number: 3227
Aitch
Username: Aitchgb1
London
UK
Registered: Feb-10 Posted on Sunday, February 21, 2010 - 10:23 am:
GM0300W6724361
Apologies -
90 533 422
Try code 3451
Post Number: 3228
charles ana
Registered: Feb-10 Posted on Sunday, February 21, 2010 - 10:07 am:
Hi,
Can you help?
Mine's...
GM 1300V6429438
7645852320
90 532 620
Try code 6748
Username: Nodnodwinkwink
cheers reg rooster, that sorted it.
Username: Michel71
helloooo
I need a code too in my radio
GM030M Y5862031
7 649 852 520
90 533 422
CAR 300 (F)
Thanks!!
Username: Alloagc
Hello all,
first timer here and a frustrated one at that, what i thought was a simple task has turned out to be a real labour.
I am looking for guidance and some help if possible. my wife has a vauxhall corsa which has had a list of faults and the latest was a flat battery - and as a result now has a code protected radio. i have spend hours trawling online, downloading code generators (which have all failed to generate a working code), i have even tried to get a local guy to come and i would pay him - but after several failed appearances i have given up.
i have a small issue as well and it could be my stupidity - all these code generators produce codes of 4 digits which is fine, however the last one was 7056 --- the radio we have only has 1,2,3,4,5,6 on the radio facia, so i have no idea how to input the number :-(. she has the blaupunkt car 300 d.
can anyone tell me a place or a way to get the code?
thanks for looking and for any help you offer
Username: Misha88
Kiev
Post Number: 56
Hello alloagc! for an input there is a code. It is needed:
1. to include lighting.
2. to push the button AS, on radio, not releasing plug in radio
3. push button 1 to the necessary value of the first number code.
4. push button 2 to the necessary value of the second number code.
5.iaæeiaéoa button 3 to the necessary value of third of number code
6. push button 4 to the necessary value of fourth number code
7. further push button AS and hold 5-10 seconds.
if a code is faithful that radio will begin to work.
request to write to me after verification on
magnitola2010@rambler.ru
Mikhail.
Username: Misha88
Kiev
Post Number: 57
5. push button 3 to the necessary value of third of number code
Mikhail.
Post Number: 3273
michel
Username: Michel71
Registered: Feb-10 Posted on Friday, February 26, 2010 - 11:25 am:
helloooo
GM030M Y5862031
7 649 852 520
90 533 422
CAR 300 (F)
Try code 0154
Username: Meho_m
Hii, can anyone help me, i have Opel Astra F and ... the rest is typical, remove battery and now code needed!!!
Type: CAR 300 (D)
Serial: GM0300V6150502
Part No.: 7645852520
NO: 90532620
Username: Hay88
Post Number: 115
meho m try code 5144
Username: Meho_m
it works...thanks
Username: Scoots74
ChelmsfordUK
Hi Reg Rooster,
Would be very grateful for a code after I disconnected battery to clean EGR and Idle Valve. Never even thought about the radio at the time. More fool me.
Car 300 (E)
7 649 852 320
GM 0300 X 5159987
90 533 422
02 1465
8 635 132 822 Index 2
Username: Hay88
Post Number: 118
hi simon try code 7761 hope this helps
Username: K921
Portsmouth, Hants UK
I have a blaupunkt car 300 (F)
7 640 852 520
made in malaysia
GM030M23072193
No:24 455 376
Type:CAR 300 (F)
2F2
Username: Hay88
Post Number: 125
hi kevin i can help but you got to many numbers after M can you double check please
Username: Hay88
Post Number: 126
kevin you can try 7540 but if wrong please check the GM number again it makes a change to help a neighbour from pompey lol
Username: K921
hi hay88 i have 8 numbers after M
Username: Hay88
Post Number: 128
have you tryed the above code
Username: K921
i have not tryed the code yet as it is for a work van i wii try it tomorrow
and let you no if it works. thanks
Username: Scoots74
ChelmsfordUK
hay88Silver Member
Username: Hay88
Post Number: 118
Posted on Tuesday, March 16, 2010 - 03:18 pm:
Thanks very much Hay88, it worked straight off and very pleased to be listening to radio instead of talking to traffic. Let me know if I can get you a pint when in Chelmsford!
Username: K921
Thanks very much hay88 the code worked perfect.
Username: Pradevic
Where can I find GMxxxxxxxxxxx serial???
Username: Hay88
Post Number: 195
hi pedja you have to remove the the radio and it will be stamped into the metal caseing and maybe on sticker you need two GMXXXXYXXXXXXX AND 7 XXX XXX XXX
Username: Pradevic
Thanks!
GM30M15935082
7 649 852 520
Username: Pradevic
Oh sorry, it's
GM030M15935082
7 649 852 520
Username: Hay88
Post Number: 198
hi pedja try code 9356
Username: Pradevic
It works! Thanks a lot!!
Username: Reveritt
hey can i get a code for mine? ?
GM0300W5428548
7 647 852 320
Regards, Ricky
Username: Hay88
Post Number: 258
hi rix try code 3266
Username: Reveritt
thank you, will give it a try
Username: Lion_7
Hi -- could I get a code for..
Blaupunkt Car 300 (E)
GM0300Y6264286
7 649 852 320
Mad in Portugal
Thanks in advance!
Post Number: 3520
LSR
Username: Lion_7
Posted on Thursday, April 01, 2010 - 11:34 am: Edit Post
GM0300Y6264286
7 649 852 320
Mad in Portugal
Try code 4494
Username: Lion_7
Thank you! Worked perfectly
Username: Stevebeer
please help !!!!!!
can someone give me the code for
gm300s2060616
7 645 852 520
90 462 559
Post Number: 3522
stevebeer
Username: Stevebeer
Posted on Thursday, April 01, 2010 - 01:33 pm: Edit Post
please help !!!!!!
gm300s2060616
7 645 852 520
90 462 559
Try code 1902
Username: Hajdusek
please help !
GM1300V6644638
7 645 852 320
90 532 620
Thanks
Username: Hay88
Post Number: 301
hi shrederko your code 1920
Username: Andzej1
Please help!
Need code for:
GM0300Y6216690
7 649 852 320
90 533 422
Car 300 (F)
Made in Portugal
Thanks
Username: Hay88
Post Number: 319
Andzej1 try code 9541
Username: Ltvarrb4
Hello!
Can someone help me to get the code for...
GM030M23000470
7 640 852 520
Thanks!
Username: Hay88
Post Number: 322
hi Ltvarrb4 try code 2910
Username: Lena79
BG
Hi,
I have Blaupunkt CAR 300 D
No.: 90 532 620
GM 0300 T5 172392
Can anyone help Pls
Username: Hay88
Post Number: 324
hi Lena79 try code 5660
Username: Lena79
BG
Thakns
That's it!
Username: Rcata20
Hi,
No.: 90 532 620
GM 0300 T5 110971
Can anyone help Pls
Username: Hay88
Post Number: 343
hi Rcata20 try code 4004
Username: Parker3048
hi i wondered if anyone could help me.
i have a vaxhall corsa t reg
blaupunkt car300 (e)
serial-gm0300x9543863
made in portugal
would like a code to un-lock if possible
thanks very much
ben
Username: Misha88
Kiev
Post Number: 78
Hello Mr Parker! your code of radio 3327
write to me on
after his verification
Username: Xantony
Hello!
Please give me a code to unlock my radio
Blaupunkt Car300 (D)
Serial: GM0300W507653
7 647 852 320
90 532 620
Made in Portugal
Thank you very much
Username: Hay88
Post Number: 451
GM0300W507653 < number is to short.
Username: Xantony
Sorry, number is GM0300W5074653
Username: Misha88
Kiev
Post Number: 88
Hello your code of radio 1016
write to me on
Username: Xantony
Thanks, i'll try it!
Username: Miguelknight
I aul hello from Spain to see if you can solve my problem with my cassette
balupunck type car 300 (d) autostore
no. 90 532 620
7 645 852 520
gm0300T5216544
Username: Hay88
Post Number: 505
Miguelknight
TRY CODE 8447
Username: Xantony
Misha88
Code doesn't work
Username: Hay88
Post Number: 513
anton please check GM0300W5074653 = 1016
if thats right what make car is it in.
Username: Xantony
hay88, my radio has not display.
after entering the code i hear a short signal.
what does it means?
Username: Hay88
Post Number: 514
Xantony
if you dont have a display when entering it will go like 0 1 2 3 4 5 6 7 8 9
so when entering you would have to push button 2x to get the one then button 2 once to get 0 then push button 3 2x to get one then button 4 7x to get the six.then Press & Hold Preset " AS " Until the Unit Beeps. bear in mind it may go 1234567890 when pushed.
if so
button 1 1x =1
button 2 10x =0
button 3 1x =1
button 4 6x =6
thank you very much sir hay88 drive my car now is nothing
Username: Manamaxl
Hello!
Blaupunkt Car300 (E)
Serial: GM0300W8559063
7 648 852 320
90 533 422
Made in Portugal
Thanks from Holland, Marcel
Username: Hay88
Post Number: 544
Manamaxl
try code 8559
Username: Manamaxl
Great!! Thank you Hay.
Username: Xantony
hay88, thank you! It works!
Username: Matt46cars
Hi
can i get a code for blaupunkt 300 (E)
2f2
90 533 422
gm0300V8273220
had to change battery and didnt realise it was a coded unit
Thanks
Username: Misha88
Kiev
Post Number: 95
Hello! Information for being code not complete.
7 *** *** ***?
Write to me on mail of
Username: Hay88
Post Number: 581
Matt46cars
try code 0527
Hi
hay88, sadly that code didnt work, tryed it twice, now says 8 safe which i assume means 8 more trys left???
any other codes?
I double checked info on radio and only thing i can think is thats "gm0300V8273220 " the "v" could be a "y" but as i say i aint sure?
Can you check it with a y for me, hopefully it is if it works, no music sadly sucks
Apreciate all the help
Thanks
Username: Misha88
Kiev
Post Number: 96
I told you that does not seize yet a number
7 *** *** ***
Username: Hay88
Post Number: 589
Matt46cars two thing can you please post the 7xxx xxx xxx number and what make car. thanks
Post Number: 3686
matt46cars
Posted on Sunday, April 25, 2010 - 11:53 am:
Hi
2f2
90 533 422
gm0300V8273220
The code for a Blaupunkt CAR300 with a Serial Number gm0300V8273220 is definitely 0527 as already quoted.by hay88.
The problem will be
1..Wrong serial number quoted
or
2..Wrong code entry
or
3...Radio has been recoded in the past to a completely different number to the one it left the factory with.
Username: Martynas
Hello, may you try to get a code for my Opel Astra 98:
Type: BLAUPUNKT CAR 300 (D)
No: 90 532 620
S/N: 7 647 852 320
GM0300W5278231
Many Thanks!
Username: Hay88
Post Number: 591
Martynas
try code 2224
Username: Krzysieks
hi,
can you please help me with code to CAR300D
number: GM 0300W 5408039
someone asked me to try 1677 but it does not work
thanks,
Username: Misha88
Kiev
Post Number: 97
Kris! Information for being code not complete!
1.GM 0300W 5408039
2.7 *** *** ***?
Username: Krzysieks
Misha88,
1. GM 0300W 5408039
2. 7 647 852 320
No: 90 532 620
Type CAR300D
many thanks in advance
Username: Hay88
Post Number: 603
hi Kris 1677 is the code for the given numbers. how to enter below.
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Username: Hay88
Post Number: 604
Kris has it got a display if not:
if you dont have a display when entering it will go like 0 1 2 3 4 5 6 7 8 9 or bear in mind it mite go 1 2 3 4 5 6 7 8 9 0
Username: Krzysieks
Hay88,
this is how I am entering a code - the only difference is that last time I had SAFE and then 9 (because I tried once already earlier)
and once I enter the code and hold again AS then after beeps I get displayed SAFE again
any idea why this code is not working?
Username: Krzysieks
I have a display there
Username: Hay88
Post Number: 605
it may have been recoded:
The problem will be
1..Wrong serial number quoted is it the one that is stamped into the metal casing.
2...Radio has been recoded in the past to a completely different number to the one it left the factory with.
ps. dont waste you try's you only get 10
Username: Thorpster
Hello can you help please? Radio code required.
Blaupunkt Travel Pilot X
TP EXCD 132
BP051366211707
7612300513
5S7T 18K931 BA
Many Thanks
Post Number: 3725
Thorpster
Username: Thorpster
Posted on Friday, April 30, 2010 - 08:26 am:
TP EXCD 132
BP051366211707
7612300513
5S7T 18K931 BA
try code 8913
Username: Thorpster
To Reg Rooster
That worked. Thank you very much.
Thorpster
Username: Django
Hello
Blaupunkt
Radio Type - Car 300E
No.90 533 422
GM 0300Y82388761
7649852320
Correct Code No. required please
Thanks in advance
Username: Hay88
Post Number: 692
Django
try code 0527 if not please check GM 0300Y
cause should be 7 digit not 8 kk
Username: Musicmann
Hey Just bought my frist we car 2day, and has one of these car 300 radios in it, Need a code for the choons,
Car 300 (E)
Serial GM0300M6764470
Part No 7 648 852 320
also got these numbers on it
90533422
2F2
Many thanks in advance
Post Number: 3743
Music Mann
Username: Musicmann
Posted on Tuesday, May 04, 2010 - 01:20 pm:
Car 300 (E)
90533422
2F2
Try code 5 1 2 7
Username: Musicmann
there is no 7 on my radio,,,
only 1-6
Username: Hay88
Post Number: 694
Musicmann thats the code how to enter below.
Username: Musicmann
the is no display thou
Username: Hay88
Post Number: 696
musicmann bear in mind it mite go 0 1 2 3 4 5 6 7 8 9 so
If it starts 0, 1 , 2 then if i want to enter 5127 you would press:
"1" 6 times
"2" 2 times
"3" 3 time
"4" 8 times
Username: Jimkarl
Someone please help with a code for
Blaupunkt
GM0300S2255497
part no 7645852520
Thanks
Username: Hay88
Post Number: 704
Jimkarl
try code 7049
Username: Ajaw83
Someone please help, i have a plaupunkt car 300 (F):
SN: GM030MY5831803
Part No. 7 649 852 520
Thanks.
Username: Misha88
Kiev
Post Number: 100
your code of radio 2236
write to me on
Username: Ajaw83
i have sent you the e-mail thanxxx man it worked....
Username: Dewan
Hi, Please help!!!!!!!!!!!
I need code for:
Blaupunkt
NO.:90 532 620
Type: car 300 (D)
7 645 852 320
GM1300V6425576
thank you
John
