Video Converter..any1 kno where to find 1 ?
need2no
hey..this is a lil off topic but where can i find a video converter so i can convert my avi files into .wma or mpeg4 so i can put them on dvd-r discs and watch them on my tv ?? anyone know?
Username: Illuminator
Post Number: 2249
dvdsanta does it.
Username: Abdou91
514
Post Number: 38
mininova *org eplace the * with (.)
get any software you like i use avi/mpeg...converter it works
Username: Appzalien
Cleveland, Ohio US of A
Post Number: 49
What makes you think converting avi to wma or mpeg4 will play on the tv from a dvd-r disk? If you have a player that will play wmv (wma is windows media audio) or Mpeg4 than I would suspect it will also play avi (Divx compatible player). What I think you need is to convert avi to vob files that can be burned to dvd. Vob files are Mpeg file packets along with ifo files they make up a dvd video.
Username: Ruby310
I have a video.avi in a foreign language and subtitles.srt on the other hand.
Could you tell me what software I should use to include subtitles in video.
Thank you to help me
Need to Register?
Forgot Password?
Enable HTML code in message
