Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1561 Registered: Jan-08 | Whats up dudes? I want to do this ![]() but i want to build an actual ported box for the subs rather than IB. I want to completely seal the subs off from the trunk. My main concern is what do i do about the bracing that is in the rear deck? I assume i cant just cut it out without putting in bracing somewhere else. Have any of you guys done this? If you have, install pics would be great. I could use any suggestions on how to start. Car is a 4dr 1999 alero subs are 2 12" idmax Thanks |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1562 Registered: Jan-08 | Come on ecoustics, dont let me down. |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 8437 Registered: Mar-04 | Chop it up. Its just sheet metal |
Silver Member Username: Chevyfan502AQ HDC315AQ 2200 Post Number: 198 Registered: May-06 | that car is a uni-body, meaning that rear deck is part of the structure of the car as a whole. if you hacked it up, you could initiate rear window leaking among other things due to the sides of the car being able to shift back and forth easier. Definitely re-brace well. |
Gold Member Username: Van_manBoston South, MA Post Number: 5421 Registered: Mar-06 | Kevin, I would sandwich the deck with 3/4 ply. The top can be wrapped with cloth, The bottom can be used as the box. Then caulk the metal inbetween them. That will solid it up. |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1563 Registered: Jan-08 | There is some cross bracing for the arms of the trunk lid. It is right under the rear deck, and needs to move for the trunk to open. Any ideas on what i could do about that? |
Gold Member Username: Van_manBoston South, MA Post Number: 5422 Registered: Mar-06 | well, Just 3/4 ply the top, then shoot screws from underneath to secure it...idk how you will be able to seal it then if they are in the way of the box...Pics? |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1564 Registered: Jan-08 | Yeah, I can get pics up soon. |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1565 Registered: Jan-08 | ![]() ![]() Im kinda thinking I could try to take out all of the hinges for the trunk and install some trunk struts because they would be out of the way. Anyone know where i can get a kit for a 99 olds alero? |
Gold Member Username: Van_manBoston South, MA Post Number: 5427 Registered: Mar-06 | idk if they make an oem strut for that model year. You may need to fab on in your self. Should be able to find gas struts pretty easy. JC Whitney for sure. But that would free up alot of space back there. Another route would be to box them in as tite as possibe with mdf, while still allowing movement for use, then foam around them as best as possible. wait, that wont work as they are still in the way of the subs. Get a new car with out those springs..Problem solved. http://www.partstrain.com/store/?D=trunk+lid&PN=4294919068&Nty=1&Ntx=mode+matcha llpartial&Ntk=Main&N=0&Dx=mode+matchallpartial&Ntt=trunk+lid&Nr=AND(universal:0) &props=Part:Lift+Support If you want to be balling, install the hinges on the back side, (oppiste side where they are now) and use an remote controlled electric motor driven worm gear assembly to open and close the trunk. That would be badass.. |
Gold Member Username: Van_manBoston South, MA Post Number: 5428 Registered: Mar-06 | Three match your car.. http://www.partstrain.com/store/?N=0&sv=0&PN=4294919068&VN=4294967190+4294966242 +4294963990+4294967247+4294966352&Ntt=trunk+lid&Nr=AND(universal:0)&ref=partfind er |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1566 Registered: Jan-08 | Olds alero, not bravada lol. Thanks for the help Marc. I think im gunna have to figure out how to make and install some custom struts. My cousin is a master mechanic, Im sure he could figure something out for me. |
Gold Member Username: Van_manBoston South, MA Post Number: 5429 Registered: Mar-06 | lol, yea just noticed that..As stated, they dont make one for your car, So buy the pricy ones, they will hold more weight and have longer throw. Shouldnt be that hard to modify, Hardest part will be finding the correct mounting locations that will provide the right throw for the strut you choose. GL, |
