Amplifier Protection Mode
Username: Pharoah
HI, just put in my juice ja490 and my alphasonic psw112c. Everything worked fine, was testing it out a few songs and sounded great. Then all of a sudden the sub stops working, and i notice the light on the amplifier has turned from the blue power light to the red protection light. I looked online for some solutions, disconnected the sub from the amp, and the protection light stays. Disconnected the rcas, and the protection light stays. Removed the remote turn on, theres no light, and when i connect it the light comes on again. When i disconnected the rcas the light goes dimmer, is that important? Id be grateful for any help, bear in mind im only a student in sixth form so im not rolling in money. Although i admit this is probably a case of buy cheap pay twice, i want to make sure theres nothing else i can do before buying a new amp.
Thanks in advance
Username: Skdooley
Roanoke, VA Usa
Post Number: 1406
Try turning the gain (input sensitivity) down. Also make sure your ground connection is solid. Lastly make sure you have the sub(s) running at an ohm load thats acceptable for that amp.
Username: Mystre
Pemberville, Ohio USA
Post Number: 664
^ X2
Username: Pharoah
Ive realised i hadnt matched the amp and sub properly. The amp only gives out 150 W whereas the sub is 230 RMS. It was a schoolboy error really, could this be the problem causing the amp to go into protect mode?
Username: 420pimp2
Baltimore Atlantic Ci..., MD, NJ
Post Number: 1042
nope, do what SKD said.
Username: Pharoah
Ive disconnected the speakers and its still in protection mode. If tried a second ground and still no change
