Renault Laguna 51 plate
Username: Barney123
Hi can anyone help with the radio code for the model listed below. Kids are now driving me crazy and need to drown them out with radio ;)
MODEL 22DC279/62Z
PROD FDO101290129655
RN279F10129655
TOZ924
8200002607TZ924
Username: Hay88
PortsmouthUk
Post Number: 3158
Barney123
code 0018 hold at the end to store your code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and hold buttons 6 to store. for 10 seconds
Username: Barney123
THANK YOU soooooo much you have saved my sanity (and money). Going to try now
Many thanks once again.
