Renault Megane Coupe radio code
Username: Indiasummer
Hi, this is my first post and I am hoping someone might be able to help me.
I had to go to Halfords to have a new battery fitted today, they advised me I might have to obtain the radio code if 0000 came up after fitting. I have looked on lots of sites to find my code, but all say they need the serial number of the radio...problem is that I cant get the radio out without a special instrument, which I would have to buy.
I therefore don't have the serial number of the radio, is there any other way of getting the code without the serial number ?
Many thanks in advance
Username: Bogege
Post Number: 69
: Indiasummer read here::http://www.fitaudio.com/index.php?CategoryID=10
Thanks Bogege, have looked at that site, looks as though I will need to buy some din style release keys ?
Username: Hay88
PortsmouthUk
Post Number: 3153
no use an old coat hanger.
image/bmpUpload
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
