Does anyone have the code for this type of radio? The serial numbers, vin no. found on it are as follows: BP8124W6297737 7700428254 7 648 124 391 021253
Sorry, I'm not sure which number is which so I copied all the numbers & I hope that might help. Thanks
Hi, thanks for the help. The only problem is that the key pad on the radio only consists of six numbers which are 1 to 6. How do I key in number 0, 7 & 8? Thanks again.
I don`t have the exact instructions for this model but it will be something like the following
Turn on the radio, the display will show 'CODE' . Press any pre-set key and the display will show '0000'
Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ pre-set 6 ] to enter the code. The set will display 'CODE' briefly and switch on.
