Post Number: 2 Registered: Nov-10 Posted on Saturday, November 13, 2010 - 03:09 pm: Lost my radio code for a 93 audi s4 serial number is AUZ1Z7P3903964. can anyone help please and thank you. ===================================================== Duplicate post....Already answered
Hi, Just wondering if someone can help for the radio security code by the following info.: 2005 Toyota Echo (registered in Australia) Radio model: Toyota 32809 (the only info that I could found on the radio!) VIN: JTDJW133000252412 unfortunately, the first owner changed the factory code. So the code that I've got from the Toyota dealer didn't work. Thank you for your help in advance. Cheers
Post Number: 1 Registered: Nov-10 Posted on Saturday, November 13, 2010 - 11:14 pm: Hi, Just wondering if someone can help for the radio security code by the following info.: 2005 Toyota Echo (registered in Australia) Radio model: Toyota 32809 (the only info that I could found on the radio!) VIN: JTDJW133000252412 unfortunately, the first owner changed the factory code. So the code that I've got from the Toyota dealer didn't work.
If the code has already been changed from the original factory code, then your only solution is to take it into a Radio Decoding Service who will connect it to a laptop to read the code from the memory chip (EEPROM) inside your radio
Could you please see if you could get me the radio code for a car I'm borrowing for work. It's a Renault laguna 02 plate and the radio is model 22dc259/63z the product Number is fd0302100046234 and 8200002606tf443 thank you, Chloe xx
Hello all Could one of the members please find me the code for my Philips car radio Details as follows 22DC459/62S FD 0698058034668 902221459628 Thank you
post the numbers/letters from below the main barcode something like 7700xxxxxxt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you
Mullac that number 7700 426 482xxxx again can be found below the main fat barcode with a letter and three digits on the end of it. or the security code like Q123
Just purchased a Renault Megane Grand Scenic - and the radio code from the service booklet does not work, I suspect it has been replaced at some point. Could you please provide me with an unlock code for the current radio / cd?
the details are; RNRDAP60036369 RENRDW330-19 BS0106420036369 8200607918T
the details are; RNRDAP60036369 RENRDW330-19 BS0106420036369 8200607918T T491 - SECURITY
My last hope. Had to disconnect battery in 2004 Seat Cordoba, and have lost radio code, Radio is a Grundig Alana Model No 6L0035156 9.18428-81 G.HM91.00 Serial No SEZ2Z9C2814083.
Kerry89 please check your serial m005733 = 3847 make/model ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed. Repeatedly press button 2 until the correct second digit of the code is displayed. Repeatedly press button 3 until the correct third digit of the code is displayed. Repeatedly press button 4 until the correct fourth digit of the code is displayed. Once the code has been correctly selected on the radio's display, press button 5 to enter.
Saulius code 2657 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Post Number: 1 Registered: Nov-10 Posted on Tuesday, November 23, 2010 - 03:48 pm: Hy. I lost my radio code to my vw golf V plus Radio: Blaupunkt RCD300 PM0035186B serial: VWZ2Z2G183377 ====================================================
Sorry...Main V W Dealer or a Radio Decoding service only for this VW (Blaupunkt ) code
Post Number: 2 Registered: Nov-10 Posted on Wednesday, November 24, 2010 - 03:29 am: hi, have lost code for blaupunkt car stereo serial# bp2252 31613735 7642252520 many thanks ---------------------------------------------------------------------------
Post Number: 4 Registered: Nov-10 Posted on Wednesday, November 24, 2010 - 03:48 pm: regrooster, thanks but didnt work either and ive checked and all numbers are correct ==================================================== Double checked again and still 6524
Post Number: 1 Registered: Nov-10 Posted on Friday, November 26, 2010 - 02:00 pm: car Renault S/N RNRD0140233915 thx. ==========================================
Post all the letters+numbers on any labels and barcodes
Hi, BMW 1992 525i Lost the radio code I think i am missing the serial on the back of the radio. Here is all of the info stamped or on stickers on the unit. BMW KE-91zbm 88 88 1 600 235 PMA0105803 Thanks!
hay88, I will send restoredclassic@aol.com an email. Just wanted to say thanks, I read through a lot of posts here and in the archives and you have helped a bunch of people. I know you did not have my code but you have had 80% of everyone elses. I appreciate it, and I know they do too.
Post Number: 1 Registered: Nov-10 Posted on Tuesday, November 23, 2010 - 03:48 pm: Hy. I lost my radio code to my vw golf V plus Radio: Blaupunkt RCD300 PM0035186B serial: VWZ2Z2G183377 ==================================================== This request was answered previously....and the answer is the same Sorry...Main V W Dealer or a Radio Decoding service only for this VW (Blaupunkt ) code
Post Number: 1 Registered: Nov-10 Posted on Sunday, November 28, 2010 - 08:47 pm: Hi: I need the Code for an Alpine (Mercedes front panel) N: AL 2396 V 0724406
Hi, I change the battery and I don´t have the code, I need help, please. Ford Focus II ghia 2.0 2005 mechanism part number vp3m5f-18c821-ag serial number ctv119695 m010256 thanks
Hi, our car got serviced and the battery disconnected, so the stereo stopped working. We rang the Peugeot dealership and they gave us a security code, but just typing the numbers in does nothing.
It's an Alpine CDM-7829E The serial no. on the manual is 570642 but I took the radio out just before and the label on it said the serial no. was 570575. I suppose this one would be more likely to be correct.
Switch Radio On - Display Shows " CODE " Press " FUNC " The Display Shows " 0000 " Press Vol Up " ^ " Repeatedly For Correct Digit Press Tuning " UP >> " Button To Enter Press Vol Up " ^ " Repeatedly For Correct Digit Press Tuning " UP >> " Button To Enter Press Vol Up " ^ " Repeatedly For Correct Digit Press Tuning " UP >> " Button To Enter Press Vol Up " ^ " Repeatedly For Correct Digit If the correct code number is now shown Press " TUNER BAND DAP " To Enter And the Radio will then Turn On
Same old problem here. Flat battery and now no radio for 2 months! Can you please supply the radio code for me. I drive a 2004 Renault Scenic with the following details:
Model No: RENRDW131-10 Prodt No. FD0404230154060 SECURITY: J186 rnrd0340154060
So looking forward to being able to tune in again. Cheers
Hy. I nned a code to my Renault Megane car radio: Model No: 22DC277/62 T0I370 RN277F30108605 Prod NO: FD0103060108605 Barcode nbr.: 8200256141TI370 ?? code: 029021 Thanks!
HI I need code to unlock my radio(Renault Clio II) this is number from my radio MODEL NO: 22DC 279/62E TOE 545 RN279F20065699 PROD.No 0202370065699 please help me THANKS VERY MUCH
Hi there! Can I have a code for Seat Toledo 2000 The radio is Aura and these are the numbers I found (sorry I don't know which oe you need ) SEZ1Z6X1106872 AURA 1M0035 186A 918359-8151 G.HH7800 Hope you can help me as well.. Cheers mate!
I have a Mercedes 220SLK from 2001, with a radio that needs a code entering after battery replacement. The radio serial number is AL2910 Y1159 463 B. Apparently it is not the original radio, so the car VIN (WDB1704441F191399) doesn't help, as it produces the wrong code (24111) at the dealer. Can anyone help?
Posted on Sunday, December 12, 2010 - 05:48 am: Hi there! Can I have a code for Seat Toledo 2000 The radio is Aura and these are the numbers I found (sorry I don't know which oe you need ) SEZ1Z6X1106872 AURA 1M0035 186A 918359-8151 G.HH7800 ===============================================
Sorry...Main Dealer or Radio Decoding Service only for this code
I have a Mercedes 220SLK from 2001, with a radio that needs a code entering after battery replacement. The radio serial number is AL2910 Y1159 463 B. Apparently it is not the original radio, so the car VIN (WDB1704441F191399) doesn't help, as it produces the wrong code (24111) at the dealer. Can anyone help? =================================== Sorry .....this code will only be available using a Radio Decoding Service
Code for ALPINE 2910 radios are not available from Serial Number
I have a Renault Laguna 1999 and need the code for this radio: 7700 433 074 W128 FD 11 99 25 2267218 Model no: 22DC461/62E Prod no: FD 1199252267218 Thanks.
Posted on Wednesday, December 15, 2010 - 01:09 am: Hi,
I have a Renault Laguna 1999 and need the code for this radio: 7700 433 074 W128 FD 11 99 25 2267218 Model no: 22DC461/62E Prod no: FD 1199252267218 =========================================== try code 3834
Hi, After a trip to my garage, my car radio is now asking for a code which is not wriiten in my audio manual. Could anybody help? I have a Vauxhall Astra 02 plate with a CDR500 radio (just the standard one that comes with the car). The serial number (i think) which is on the back of the panel is GM 13 107 918. Any help will be much appreciated. Cheers Ian
Posted on Thursday, December 16, 2010 - 06:26 am: Hi, After a trip to my garage, my car radio is now asking for a code which is not wriiten in my audio manual. Could anybody help? I have a Vauxhall Astra 02 plate with a CDR500 radio (just the standard one that comes with the car). The serial number (i think) which is on the back of the panel is GM 13 107 918. Any help will be much appreciated. Cheers ========================================
Unfortunately the codes for the CDR500 made by VDO/SIEMENS/DELCO are only available from the Main Dealer or a Radio Decoding Service
DUE TO RADIO FAILING TO TURN OF AFTER COLD WEATHER I HAVE DISCONECTED AND RECONNECTED RADIO. RADIO CODE WAS NOT GIVEN WHEN CAR WAS BOUGHT. RENULT MAGANE 2007
RNRDBE70161834 N204 WOULD BE GRATEFUL IF ANY1 COULD HELP
Posted on Monday, December 20, 2010 - 05:32 pm: DUE TO RADIO FAILING TO TURN OF AFTER COLD WEATHER I HAVE DISCONECTED AND RECONNECTED RADIO. RADIO CODE WAS NOT GIVEN WHEN CAR WAS BOUGHT. RENULT MAGANE 2007
Hi I have a jeep cherokee and have lost the radio code, the radio serial number is TQ1AA1450E2583, Date code: 1450. Supplier 17719a, please help taken to listening to the walkman while driving.
Posted on Wednesday, December 22, 2010 - 03:49 am: Hi I have a jeep cherokee and have lost the radio code, the radio serial number is TQ1AA1450E2583, Date code: 1450. Supplier 17719a, please help taken to listening to the walkman while driving ==============================================
