Insted of dongle can i use usb to rg45 cable netwerk cat 5 cable
Username: Habs69
i have a captiveworks 700 i wanna no if i can use usb to rg 45 cable instead of dongle.
Username: Satscanner_ca
BeaversbushGreat White ...
Post Number: 137
You can do whatever you want, I'll never tell.
Shouldn't your question be : Will a rg45 to usb cable work instead of a "dongle" ? Thats a different can of worms altogether.
Post Number: 138
Frank, aren't ya glad you took time to register and posted here now?
Diamond Member
Username: Nydas
Post Number: 20436
fanksmith404: Actually CW 800 and probably the CW 700 are the only receivers that I know off which may work without a dongle. If you subscribe to NFPS, you can connect via your computer with some software directly to the two CW receivers mentioned above. It was originally developed under Linux and there is a windows version of software available.
There may be other receivers too.
Remember it is only related to NFPS.
Post Number: 145
Nydas, you never answered his question; i wanna no if i can use usb to rg 45 cable instead of dongle.
Answer; no
Diamond Member
Username: Nydas
Post Number: 20439
The answer is : The way to connect is via computer - no dongle needed.
And idiot Satscanner. Stop trying to hound me. Others have tried and failed.
Post Number: 148
Agree, you don't need a dongle but you can't use rg45 to usb numb nut's.
Username: Harding
Post Number: 331
Mr. Satscanner:
I hate to interrupt.
Don't you think, Sir, that Mr. Nydas has fully answered the question?
Just my two cents, as some people say.
Diamond Member
Username: Nydas
Post Number: 20456
Humble: don't bother with them. They are very difficult to deal with.
Username: Chaff
Post Number: 545
use serial cable
Username: Chevrolet
Post Number: 473
Username: Harding
Satscanner pay no mind to Harding just like Nalin
he don't know Shjt
some here had said that Harding is Nalin
