I needed a new battery & as you can already guess i lost my radio and don't have the code to reset it. The details are as follows:
Model No. 22DC277/62 TW368 RN277F30346813 Prod No. FD0303470346813 8200256141TW368
Sorry there's a lot of numbers, i just jotted them all down to make sure i had everything! I would be eternally grateful if you could please let me know the code i need....i can't bear the silence anymore
I needed a new battery and i lost my radio and don't have the code to reset it. Model No. 22DC277/62 T978 RN 277F40647176 PROD NO. FD0704370647176 VIN VF1KMR00632630686 BAR CODE 8200256141TT978
I had the same problem with my car and I solved it visiting kijiji.it,I found a cheap solution at http://www.escran.com/detail.asp?id=125858 and he/she solved my problem rapidly.Follow my way if you want and good luck!
