New member Username: Fatalix
Post Number: 1 Registered: Dec-10
Posted on Bonjours j ai perdu le code de sécurité de l'autoradio de mon alfa 156 SW modele 2002 suite a un changement de batterie. C'est le modele d'origine de la voiture (marque blackpunt) BP-Nr: 7 640 378 316 Prod-Nr FIAT 156 034 209 0 Encore merci pour le coup de main |
Gold Member Username: Hay88
PortsmouthUk
Post Number: 3033 Registered: Mar-10
Posted on Fatalix please post the main BP0378xxxxxxxx number |
Post Number: 2 Registered: Dec-10
Posted on ok sorry I didn' t notice that you need this code 815 BP0378 225 940 68 Thank you for your post |
PortsmouthUk
Post Number: 3034 Registered: Mar-10
Posted on Fatalix code 6435 |
Gold Member Username: Regrooster
Post Number: 5630 Registered: Aug-08
Posted on try code 6435 |
Post Number: 3 Registered: Dec-10
Posted on That's work!!! Thanks for your help all; |
