New member Username: Saskboy02Post Number: 10 Registered: Nov-09 | I upgraded my computer to Windows 7 and when I hooked everything back up my receiver is not populating my IP address/sub/gate. All the lights are showing Ethernet/Link/Power on the adapter at the receiver so I don't know why it's not recognizing my server. Any help would be appreciated. Thanks! |
Silver Member Username: Old_howardPost Number: 164 Registered: Oct-10 | Doreen will help you shortly. Don't listen to nydas or she will blow up your entire home and kill your children. |
Silver Member Username: SubashiPost Number: 115 Registered: Dec-10 | and set your dog on FIRE!!!!!!!!! |
Silver Member Username: SatopiaPost Number: 505 Registered: Feb-08 | most powerlines need to have a password entered inorder for it to give you all the needed info to connect on 1 or the other |
Bronze Member Username: Saskboy02Post Number: 11 Registered: Nov-09 | Thanks I'll wait for Doreen. |
Diamond Member Username: NydasPost Number: 20395 Registered: Jun-06 | One can read all about powerline adapters here They are essentially a wired network connection. Instead of running a separate cable from router to device, You use the existing house wiring as your cable. They are a tried and trusted technology. There are some considerations. You should not have a power bar between the house wiring and the powerline adaptor. - Must plug directly into an outlet. Otherwise you should be able to see the DHCP address given out to the particular adaptor and your receiver should show the identical IP address you received from your router. You may reset the router to make sure and then just connect the receiver (through powerline). Attach other devices and computer afterwards. There are idiots here who do not know a thing themselves and try and run down helpers. Only other people besides me who would usually give reasonable advice are Plymouth, and sada and lately Jason Bourne has started posting. Vann is also OK and there are several others. |
Gold Member Username: Saqeeb9000Post Number: 7522 Registered: Oct-07 | u need to plug ur power adapter diretly to wall outlet... |
Bronze Member Username: Saskboy02Post Number: 12 Registered: Nov-09 | Thanks Nydas. Some of the comments about burning my house down & setting my dog on fire made me wonder who the serious replies were coming from! I'll try what you suggest as I do have the adaptor plugged in to a power bar. I've also made a note of who to take seriously. |
Bronze Member Username: Saskboy02Post Number: 13 Registered: Nov-09 | Thanks Sada. I'll have to free up some space on my wall outlet. |
Silver Member Username: KrishnPost Number: 430 Registered: Sep-06 | Barry: If you have shortage of outlets, you can get a powerline adapter, that has an Ethernet port as well as an AC outlet to which you can plug in your power bar, see the following URL, there is a video as well http://www.buy.com/prod/zyxel-pla407-homeplug-av-200-mbps-powerline-adapter-w-ac-pass-through/q/loc/101/216551543.html |
Silver Member Username: KrishnPost Number: 431 Registered: Sep-06 | The adapter is plugged to the wall outlet |
Silver Member Username: KrishnPost Number: 432 Registered: Sep-06 | Another source: http://www.amazon.com/ZyXEL-HomePlug-Powerline-Wall-Plug-Adapter/dp/B003ULOZ5W There are some idiots who try to bash those that have technical knowledge, by using same nicks. Watch for the Username in posts, since that is unique |
Silver Member Username: KrishnPost Number: 434 Registered: Sep-06 | Chevrolet: You cant plug a powerline adapter to a power bar. You show a power bar which he already has, if he plugs in his powewerline adapter to it, it just wont work. His options are either the solution nydas suggested or what I suggested. Don't open your mouth and show your stupidity when you don't know. Chevrolet Silver Member Username: Chevrolet Post Number: 423 Registered: Sep-10 Posted on Thursday, December 16, 2010 - 09:14 am: Saskboy02 Thanks Sada. I'll have to free up some space on my wall outlet. Saskatchewan Boy need more wall plugs try one of these |
Platinum Member Username: PlymouthCanada Post Number: 15733 Registered: Jan-08 | Nalin and real Subash Registered: Sep-06 are right about those idiots! Power off all Modem, Router, Hub, and receiver then power up in this order: Modem, Router, Hub and receiver then see if it work! |
Bronze Member Username: Saskboy02Post Number: 14 Registered: Nov-09 | Thanks Doreen & all other legit contributors. Changed adapter to wall plug/rebooted receiver & all is well. Thanks again!!! |
