I think i may need to give some more numbers, not sure what is needed so here are them all! R281 RNRDAN60050116 RENRDW330-09 BS0106270050116 8200607915T
Emma_cannon code 8717 hold at the end to store your code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
